copper lines
Old 03-28-2006, 05:03 PM
1955effie's Avatar
1955effie
1955effie is offline
copper lines
looking to get the truck started this weekend , can i use soft rolled copper lines to hook the auto trans up as a temporary fix ?
Old 03-28-2006, 06:22 PM
rclarke's Avatar
rclarke
rclarke is offline
Short term only, copper will work harden from vibration and eventually break.
Old 03-28-2006, 06:56 PM
53fatfndr's Avatar
53fatfndr
53fatfndr is offline
NAPA carries cut lengths and is reasonably priced, you just need a tubing cutter and bender.
Old 03-28-2006, 07:25 PM
stuart1's Avatar
stuart1
stuart1 is offline
Get some 5/16 brake line. The kind with a metal coil around it.
They come in various lengths. 2 - 5 foot pieces should do nicely.
With the steel coil you can bend without fear of kinking it.
Old 03-29-2006, 03:05 AM
1955effie's Avatar
1955effie
ok , all i want to do is fire the engine up so i can hear it run . it is no where near ready to be road tested . i wasn't sure what the tranny fluid might do to the copper .
Old 03-29-2006, 04:12 AM
stuart1's Avatar
stuart1
stuart1 is offline
Nothing will happen to the copper line.
If you just want to fire it up install a short section from fitting to fitting.
If it is not being driven no heat will be encountered.
Old 03-29-2006, 01:50 PM
1955effie's Avatar
1955effie
thanks !!!!!!!!!!!
