1978 - 1996 Big Bronco
Which headers?
Old Mar 29, 2006 | 12:29 PM
69ford99's Avatar
69ford99
Will the bassani y-pipe bolt to any headers or just bassani headers?
Old Mar 29, 2006 | 01:15 PM
poffutt's Avatar
poffutt
Good question. I thought I knew the answer, but the more I read your post the more I realized I'm not sure. My thought is, is that bassani will bolt up to your stock manifols, so I would imagin that it is a typical fitting.
Old Mar 29, 2006 | 09:27 PM
94 XLT White/ Silver 302's Avatar
The Bassani Y pipe will bolt up to manifolds and headers from other manufactures, but you may have to buy the flange kit Bassani sells to get a good seal using another brand of headers. I had to use the flanges with my Hedman headers, they aren't very expensive around $25.00 I bought my Y pipe and flanges from Proficient Performance.com
Old Mar 29, 2006 | 11:09 PM
greystreak92's Avatar
greystreak92
The Bassani Y-pipe is designed to fit with Bassani's headers or the OEM manifolds without the need for gaskets. As to what OTHER manufacturer's headers may work as well, I have no idea. They would have to be "direct replacement" parts for the OEM manifolds in order to work.
gildardo01
Jun 21, 2013 05:19 PM
150ford
Exhaust Systems
Feb 13, 2010 08:55 PM
Hausladen
Exhaust Systems
May 4, 2004 08:03 PM
jimbo81587
Jan 22, 2003 10:06 PM
gl51ford
Feb 20, 2002 11:05 AM
