Sponsored by: Real Truck
Torque on oil pan?
Old Mar 28, 2006 | 09:20 AM
Antacus's Avatar
Antacus
Torque on oil pan?
Anyone know if there is an official torque spec for the oil drain nut? For years I have just went snug then a quarter turn past. Either this last oil change I forgot the quarter past or that was not tight enough as I had a very small drip (about softball size) from overnight.
Old Mar 28, 2006 | 10:40 AM
Rancha9's Avatar
Rancha9
I don't have any torque specs for the 6.0, but if you tightened it as much as you used to, and it leaked a little, you might want to replace the copper crush washer on the drain bolt. It's only a buck or two, but it needs to be done every once in awhile... Also, make sure the seating surface where that washer sits is clean. Just one little grain of sand or dirt can scratch that copper washer and make it leak.
