Axle Code 26
Old Mar 27, 2006 | 10:56 PM
lombodml's Avatar
lombodml
Axle Code 26
Can anyone tell me what Axle code 26 is on a 2004 New Body F-150?
Old Mar 28, 2006 | 12:11 AM
the4by4freek's Avatar
the4by4freek
When you find out let me know also. I still can't find an answer to that question!
Old Mar 28, 2006 | 10:48 AM
is300wrx's Avatar
is300wrx
look under articles on this site..there is a decoder...
Old Mar 28, 2006 | 10:53 AM
92merc's Avatar
92merc
Probably a 3.73 Non-LS open diff. It wasn't listed on the decoders under the F150. But I found a note that a 26 is found on the 250. So I'm only guessing.
Crawl under the truck and look at the metal tag bolted to the diff. The first 3 is probably drilled through for the bolt. But you should be able then to see the 73. Other possibilities are most likely a 55 for 3.55 gears. I'd be surprised if you had something other than 3.73 or 3.55.
Old Mar 28, 2006 | 11:46 AM
KevinM's Avatar
KevinM
9.75inch 3:73 gears
Old Mar 28, 2006 | 10:18 PM
the4by4freek
Thanks Kevin! Is it an open diff or LS? Thanks in advance!
Old Mar 29, 2006 | 07:55 AM
92merc's Avatar
92merc
Definetly open diff. The LS models have an alphanumeric designation. The opens have just two numbers.
MAP37692
Dec 27, 2016 03:46 PM
d_gant
2004 - 2008 F150
Apr 25, 2016 08:24 PM
Norton72
Jun 25, 2012 08:03 AM
fordyduty
Feb 24, 2010 01:22 PM
briansspeedshop
Mar 20, 2005 03:23 PM
