Computer Chips & Tuners
Check engine with Edge
Old Mar 27, 2006 | 09:34 PM
stealth1's Avatar
stealth1
I have a 02 PSD and just put the edge w/monitor, afe stg. 2, 4" magnaflow. The question is everytime I accelerate on any setting I get the engine light. The owners manual says this is emissions code. It clears after a few minutes but I have tried every setting set up possible and it is very aggravating after spending all this $$$. I drive easy or hard and the results are the same. Is there a solution for this?? Thanks guys...
Old Mar 28, 2006 | 01:00 PM
pronstar's Avatar
pronstar
What code is it throwing? Get a code reader and you'll be able to see exactly what the issue is. That's the first step to finding a solution.
It could be something very simple. On newer vehicles, it's often very easy to diagnose and fix a problem, especially if it is throwing a code.
