Sponsored by: Real Truck
Replacement headlights
Old Mar 27, 2006 | 06:41 PM
davidw221's Avatar
davidw221
I have a 2K PSD, and I would like to get the newer clear headlights, E-bay has several different brands, and they say in their adds, NO mods needed, but I just don't trust those adds. Does anyone have experience with any of the brands listed on E-bay. If so what are the best and the easiest to install. I also would like to replace the corner lights too, so I have the same question for that issue.
this forum has been great, and gives great advise.
thanks, wannabe, 2004 PSD!
Old Mar 27, 2006 | 08:04 PM
Hockycop's Avatar
Hockycop
I have a 1999 SD and got the CRYSTAL HEADLIGHTS and clear corner lights. Check out my gallery. I think the look is much better. Very easy install......
Old Mar 28, 2006 | 04:36 AM
RACERX7775's Avatar
RACERX7775
if you are gonna spend money to change your headlights, why dont you change them to the 05 06 light assemblies. aftermarket lights are junk, they leak, they fill up with moisture, and the lights that hockycop has, i have them from the factory....some that you get aftermarket are ok but you are taking your chances... i would only get lights if they said FORD real big on the boxes.....
Old Mar 28, 2006 | 08:15 AM
Cuda444's Avatar
Cuda444
One thing to note:
As long as you have the older "Clouded style" headlight, the swap is a breeze. However, if you have the sealed beam on the XL, it becomes more of a project.
I agree with the others. Switch to only Ford branded lights... The aftermarket is full of garbage and is very hit or miss.
Tom
