High oil pressure?
Old Mar 27, 2006 | 06:28 PM
1FordMore's Avatar
1FordMore
Cool High oil pressure?
I have an '84 Ford F-150 with an I-6 300. Just recently after changing the oil i noticed the oil pressure was runnin near H on the gauge. I believe the pressure sending unit may be bad but havent tested it (plug is on properly to) I use 20W-50 oil, but i never had a prolbem with high pressure before the oil change. Any input would be appreciated.
Old Mar 27, 2006 | 06:29 PM
ford390gashog's Avatar
ford390gashog
how cold is it where you live?
Old Mar 27, 2006 | 06:46 PM
1FordMore's Avatar
1FordMore
I live in florida its around 70-80 right now.
Old Mar 28, 2006 | 05:37 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
20w-50 is a little thick I would have thought.
are you using the same weight oil as you did last time?
Could be an oil passage plugged off I suppose, increasing pressure at the sender.
Did you overfill the engine?
Have you noticed any oil coming out of the oil filler?, the dipstick? Had a toyota pump out all it's oil, and have high pressures.
Try changing your oil to a 15w40 deisel oil. I woundn't recomend any of the newer SM oils in our older engines. Check out the oil and lube forum for some nightmares on this SM oil ruining lower ends in certain engines.
Some ideas. People with more experience may be able to help more.
Old Mar 28, 2006 | 06:07 PM
quicklook2's Avatar
quicklook2
what kind of oil filter?
even motorcraft that are brand new are sometimes faulty.
if all you did was add new oil and new oil filter, than one is bad and i pick oil filter.
Piolet
Jul 19, 2014 11:06 PM
Thorkel
Jul 5, 2014 09:42 PM
Ten13
Aerostar
13
Mar 6, 2006 03:31 PM
chellebell101
1983 - 2012 Ranger & B-Series
Jan 5, 2004 02:18 PM
brianoki
Apr 15, 2003 04:17 PM
