windshield moldings...
Old Mar 27, 2006 | 01:35 PM
tgowers's Avatar
tgowers
on my 1968 f 100 there is chrome trim around the windshield and the rear window. i need to replace the rubbers on both windows....what is the best way to change the rubbers without bending and tearing up the chrome? the chrome is probably aluminium, or stainless.... and does anyone have a part number for those rubbers? thanks guys.
-tgowers
Old Mar 27, 2006 | 06:06 PM
thesprocket26's Avatar
thesprocket26
You just gently pull out the trim. Is your windshield still good? I had a glass company do it, but I needed a new windshield. They used glass cleaner to lube the gasket and slid in the trim from the outside inward. Make sure that the trim doesn't slip out. It took 2 guys 1.5 hours to do mine.
Old Mar 27, 2006 | 06:15 PM
idealtrucks's Avatar
idealtrucks
The easiest to get the chrome out without risking bending it is cutting the rubber on the inside of the truck and setting the windshield out. Then you can just pull the rubber away from the chrome with no risk of damaging it.
Old Mar 28, 2006 | 09:45 AM
tgowers's Avatar
tgowers
what about getting the trim back on without damaging it? thanks for the tip.
Old Mar 28, 2006 | 10:43 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
I was told that the rubber comes both ways, one with a groove for the stainless trim and one without the groove. The windshield should be the same as the back window, install the stainless trim first before installing window in the truck. I installed the window without trim, not good as the window has to come out to install the trim.
.....=o&o>.....
Old Mar 28, 2006 | 02:59 PM
idealtrucks
It's hard to do...I had a friend that owns a glass shop come and help put mine it. Had to put the chrome in first, like Beemer said, which is hard enough in itself. Then we had to tape the chrome in the rubber until it was in the truck. Then just take the tape off.
Old Mar 29, 2006 | 10:36 AM
tgowers's Avatar
tgowers
thanks guys. i was thinking the trim needed to go on first... you guys saved me a new headache. thanks, tgowers
Old Mar 29, 2006 | 08:41 PM
"Beemer Nut"
The wife helped me on the back window the first time, I used .090" weed eater line to pull the rubber lip inside the cab with the help of the wife keeping pressure on the outside with dish soap, a easy job. The windshield I would try only after watching the "Pros" install one before I attack that one.
With a keg of suds we can give you another headache.
Keg....(noun)....crunchy on the outside, yummy on the inside.
.....=o&o>.....
