transmission cooler... DIY project?
Old Mar 27, 2006 | 12:20 PM
Keepitrunnin's Avatar
Keepitrunnin
I have a '93 F150 4X4 w/ A E4OD transmission. I'd like to install a cooler. How difficult is it? Any tips or tricks will be appreciated.
Old Mar 27, 2006 | 12:25 PM
radramrod2's Avatar
radramrod2
EASY! If you have access to a junkyard, you can probably find a factory one out of another truck. If you want to go aftermarket, then it's as simple splicing the return line after the radiator and plumbing in the the cooler. Mounting is fairly simple...remove the grille, mount cooler to either the radiator or the any part of the support so long as there is adequate air flow, then connect your hoses.
