1988F150 Won't start
Old Mar 27, 2006 | 05:10 AM
1988f150pu's Avatar
1988f150pu
I have a 1988 f-150 and when I turn the key over it will not do anything. All of the gauges and power comes on but nothing to the starter. I went to the starter relay and could jump over it with a screwdriver and it starts fine. I replaced the relay and still have the same problem. Any Ideas???
Old Mar 27, 2006 | 06:20 AM
LoosMaster's Avatar
LoosMaster
Change the sliding ignition switch under the dash mounted on top of the steering column about midway up from the floor. You'll have to partially drop the steering wheel to change it. It has slotted holes for adjustment of the key actuation. Might want to make sure it's tight and hasn't moved but I doubt it.
Old Mar 27, 2006 | 07:54 AM
1988f150pu's Avatar
1988f150pu
Thank you... I'll give that a try and see what happens.
