Taking off cab, slapping good cab on,tricks'n'tips?
I got a 1970 4x4 frame,drive train etc. but it got a
rusted 74 cab which is gonna get pulled off then
I'm gonna out fit this thing with a 70 cab. Any tips
or tricks that make this a nice and smooth job?
[FONT COLOR="#0000ff" SIZE="3" FACE="Veranda"]
You'll need a few friends or some safe way to lift the cab. A nylon strap through both doors is the best method. Too bad the search feature isn't on-line. There have been many good threads about this in the past. Good luck.
When I did mine I built an A frame out of 2x8's with 3 2x8's bolted together on top for the main support. Just build it tall enough to swing the cab off the frame. Then I used come along and lifted it fight off. Ive used this for many other things since then,nice to have.
When I switched frames there was two of us lifting the cab over, the cab was completely gutted it didn't weigh that much with nothing in or on it. If you have access to a two post lift then you can put the dogs or feet under the cab and lift it off and roll the frame out of the way.
1969 Ford F-250 4X4, 390 bored .030 over, carter 4 barrel carb, Terminator mufflers, NP 435, NP 205 Transfer case, HD Dana 44 w/ discs up front and Dana 60 in the rear. 90% completly rebuilt from ground up.
1995 Ford F-250 4X4, Powerstroke Diesel. Supercab longbox. 70 hp chip, isspro pyrometer and boost guages. Other than that its stock. Plans: 4in exhaust, propane injection, cd player, and possible intercooler.
