73 302 vacuum routing questions
73 F100 302/2v 3spd on the column, no a/c
After looking at Mil1on's vacuum diagram......
On my truck I have the following:
1. Vac advance goes to a tee. One of the lines on the tee goes to the carb. The other is blocked off. Should the blocked off tee goto the EGR valve? EGR valve is not hooked up.
2. On the 2 port Vacuum Control Valve (Comes off the cooling system) both ports are not connected. It appears somebody bypassed it by putting a 3 inch vac line from one port to the other. What's function of this port? Where do the lines go?
What's the correct routing for these? Thanks.
grandpas1974
04-08-2016 11:34 AM
lazzarruss
11-21-2013 04:30 AM
lazzarruss
11-20-2013 09:12 PM
LARIAT 85
07-20-2010 03:03 PM
