Removing window
Old Mar 26, 2006 | 12:41 AM
powerstroke6ltr's Avatar
powerstroke6ltr
Removing window
Have a power passenger window i can't figure out how to remove...any suggestions?!?
Old Mar 26, 2006 | 12:45 PM
powerstroke6ltr
any ideas?
Old Mar 26, 2006 | 02:54 PM
LoosMaster's Avatar
LoosMaster
I was going to post when I first read it. I was trying to remember how I did mine last year. It was a bugger to do. If I remember, I had to dimantle the motor and bellcrank system and just let it rest in the bottom of the door, plus I had a vertical support I had to remove. After that I had to sort of rotate the window a bit( rear up and forward down) and wiggle it out. I had just as much trouble getting it back in.
Old Mar 28, 2006 | 12:13 AM
powerstroke6ltr
is it possible to do by drilling out the motor rivets and removing the whole assembly?? How do i remove that danged little vent window? I unbolted the two larger bolts, but the darned track is stil stiuck on the forwardmost part./..
Old Apr 3, 2006 | 08:44 PM
powerstroke6ltr
I got it. Removed small triangle window and then slid the main window out. Wasnt' that hard at all really.
