I recently bought a project which I thought or was discribed to me as a 1940 1/2 ton. Turns out the front fenders and hood are from a 40. Here is where the questions start. This is an abandent street rod project. The cab has the filler hole for the gas on the passenger side, again not a 40. I have been told that the frame is a 42 but would it have the same number from 42-47. It is even more interesting to find that some knucklehead while boxing the front portion of the frame and installing a crossmember for a Mustang II ground off part of the VIN number. I have be able to bring up 99C643784 which might not be enough digits. I got this far in being able to read this by a combination of sandblasting and wire wheeling used on a die grinder. Which brings up another question. Does anyone know of any chemical that might be used to pull up a VIN that has been welded over? Also since the cab looks like a 40 but isn't how much fabracation will I have to do to make the front group fit? I don't mind the work I just want a 40 or a even 40 clone. Is there much advantage of using a 42-47 frame when it comes street rodding this old truck. And does anyone have any recommendation on whom to by an aftermarket rear leaf spring kit from?
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page. JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards. ….
