ford explorer 4x4
Old Mar 25, 2006 | 04:31 PM
caicco123's Avatar
caicco123
ford explorer 4x4
i am having trouble deciding which engine i would like to swap in to my explorer its a 95 and i wish to put something that will be good in 4 wheel and in 2 could someone tell me the possibilities i just got it and i want more power thanks.
Old Mar 25, 2006 | 05:08 PM
rusty70f100's Avatar
rusty70f100
There's a couple ways you could go with this. You could beef up the current motor. What you would want is pistons from a '90 to '94 Explorer 4.0L, a Comp Cams camshaft, port your heads, and get headers. This will significantly up the horsepower.
Or, you could drop a 302 in there. You'd need a different transmission.
A 351 will fit, but it will be tight.
Old Mar 25, 2006 | 06:54 PM
westtntrucker's Avatar
westtntrucker
I would think about a stroker motor, stroke a 302 to a i think its a 347. Plus a deffinate would be fuel injection. A stroker will give you gobs of torque down low for 4 wheelin' and the FI will help when you get into odd angles that would flood a carb.
Old Mar 25, 2006 | 07:08 PM
caicco123's Avatar
caicco123
i was told i could put a 5.0 in? is it true or is there a better way?
Old Mar 25, 2006 | 09:33 PM
captain p4's Avatar
captain p4
A 302 is a 5.0, so yes, you ca put a 5.0 in and that would probably be the easiest way to go if you want a v8, as the explorers came with the 5.0s and parts would be relatively easy to come by i would think.
Old Mar 26, 2006 | 05:51 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome caicco to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
