Lugging
Old Mar 25, 2006 | 08:13 AM
turdbird's Avatar
turdbird
Lugging
the owners manual says to shift at 9, 20, 30, and 49 for my truck. so when i shift at these times i am running roughly 800-900 rpms, is that considered lugging?
Old Mar 25, 2006 | 05:26 PM
85e150's Avatar
85e150
That would be pretty low. Depending on the load you have, it may or may not be a good idea. An empty half ton--no biggie.
With light loads, I figure if it's responding to the throttle--in other words, if the revs are rising and you're not stuck at 1000 rpm with full throttle, then you are ok.
With heavier loads, get more revs going.
