1960 f250 4x4 front axel help
Look for a tag bolted to the front cover. Also look for a stamping number on the axle tube near the ends. You can always remove the seal and get the number right off the seal. With the tag off the axle, I can be determined which axle you have. Look on your door tag and see what the axle code is. Post it here.
Barry
50 F-1
Barry
50 F-1
I'm not one that knows anything about your year of truck, but there's a chart that's in the back of the NPD catalogue that gives axle codes, ratios, and weight ratings for all Fords 1948 to 1989. It doesn't show a code 048 anywhere for any year. Your might keep looking for a different code number somewhere on the housing. The chart shows that the codes for 57 to 63 front axles would be either A, B, C, D, E, or F. Why the chart includes front axles for 57 and 58, though, I'm not sure since they would have been conversion years. Hope that helps.
