start up timing
Old Mar 25, 2006 | 01:17 AM
BigDmoney's Avatar
BigDmoney
start up timing
What controls the timing of the spark fire, with the fuel delivery on start up? is it dist. position? module on the dist.? comp?
Old Mar 25, 2006 | 06:27 AM
subford's Avatar
subford
I take it you mean while cranking and that you have your ICM mounted on the Distributor.
If so the ICM blocks the computer and lets it "spark fire" at base timing (10* BTDC) or at what the distributor is set at.
The injectors will deliver the fuel on command from the EEC (computer) using the IDM signal from the Ignition Coil (later truck years the IDM comes from the ICM mounted on fender).
So in a nutshell, yes it is the distributor setting.
I hope this answered your question.
Old Mar 25, 2006 | 01:33 PM
BigDmoney's Avatar
BigDmoney
yes, thank you. i have been having starting problems and i think it has come down to something wrong with the timing while cranking.
