will mustang headers fit??
Old Mar 25, 2006 | 12:43 AM
72ford360's Avatar
72ford360
will 67-70 mustang fe hooker super comp headers fit in my 72 ford 360 2wd??the reason is i can get a deal on some.
Old Mar 25, 2006 | 10:50 AM
65'f1004x4conver's Avatar
65'f1004x4conver
well i had gotten a deal on some headers a few years back. i knew they would fit the motor and that was all i was concerned with(i was in high school auto class). to make a long story short i spent about 2 weeks trying to get those to work, not sure if what they were for, but you can get truck headers cheap. unless someone else has already done that swap id just be safe and get the ones for your truck.
Old Mar 27, 2006 | 11:40 AM
Mike G's Avatar
Mike G
Depends on the flange bolt patterns. If the headers have the same verticle pattern as the heads on your truck, they will bolt on. My concern would be that they may come up a little on the short side as far as the drop, since in a car you are concerned with ground clearance....
--Mike
Old Mar 27, 2006 | 12:23 PM
fordraceboy's Avatar
fordraceboy
you can get a set of dynomax headers, the cheap ones mind you, for about $125 through summit. they have 5/16 flanges and fit real nice. it might be worth the extra cash for a drop in affair...
Old Mar 28, 2006 | 08:50 AM
77fordguy's Avatar
77fordguy
I wish they were drop in. I spent almost 8 hours trying to get my dynomax headers onto my truck. I had to lift the engine, remove starter, relocate brake lines, and hack up the tranny crossmember to get these things to fit. After that, trying to get the starter back on is a great big PITA. If my starter ever blows up, it will take 4 hours to fix because I will have to take the headers off to get to it, which means I will have to get new gaskets for the headers.
but it does aound and run a whole lot better now.
Old Mar 28, 2006 | 09:39 AM
bryyce62's Avatar
bryyce62
Didn't you know? Its the law. Nobody gets off that easy. 5 minute job, could take all day! PITA like no other.
Originally Posted by 77fordguy
I If my starter ever blows up, it will take 4 hours to fix because I will have to take the headers off to get to it, which means I will have to get new gaskets for the headers.
Old Mar 28, 2006 | 09:46 AM
65'f1004x4conver
yeah i have cheap flowtec headers and i have to have my starter and header loose at the same time to get either of them out. its a pain, but im getting pretty good at it, got it down to 20 min or so
