A good spray gun
Old Mar 24, 2006 | 08:44 PM
tomrooster-1's Avatar
tomrooster-1
A good spray gun
Can anybody recommend a decent spray gun for under a 100$ . Tom
Old Mar 24, 2006 | 08:51 PM
tomrooster-1
A good spray gun
I was looking at a Sharpe FX300 did anybody use this one. Tom
Old Mar 24, 2006 | 09:48 PM
FortyFords's Avatar
FortyFords
I like the Devilbis finishline models there is one for around $115
Rich
Old Mar 25, 2006 | 12:22 AM
kenseth17's Avatar
kenseth17
Never used one myself, but the astro iwata lph400 copy is suppose to be a decent gun from reviews on hotrodders.com. Do a search on paint guns if you get a chance to visit the site. It is a question that is brought up often. I bought a cheap iwata w400 copy off of ebay for around $35. I have a sharpe conventional I have used for many years, but wanted to try something else that hopefully wouldn't waste as much in overspray. I figured I'd try a cheapy before forking out money for an iwata or sata. I have only had a chance to spray a bumper and fenders with it so far, but sprayed pretty good on those. Also you have to look at the cfm ratings on your compressor and make sure it will keep up with the gun you are thinking of buying. Some models of hvlp guns really take a lot of air, and should have high flow fittings and regulator.
Old Mar 25, 2006 | 07:15 AM
Lazy K's Avatar
Lazy K
I would go for Devilbis, Binks or Grayco. As with most other things in life with spray guns you only get what you pay for.
Old Mar 25, 2006 | 11:06 AM
kenseth17's Avatar
kenseth17
Actually I've gotten pretty good results with cheaper guns over the years, but basically you should go in with the mindset they are a throwaway gun, and parts may not be available, or cost as much as the gun itself. For primer I always have used a cheapy. If you are doing it everyday for a living then spend the money on a good gun that if taken care of will last a lifetime, has good tolerances and machining. If you don't want to spend a bundle and only do a car or two once in awhile you can get decent results with cheaper guns, at least one good enough to be perfected by wetsanding and buffing.
Old Mar 25, 2006 | 10:03 PM
roger dowty's Avatar
roger dowty
so far I'm ok with my IR gun from lowes- $95 or something like that. I've always done ok with IR.
