390 GT identification
Old Mar 24, 2006 | 03:03 PM
oldmansimek's Avatar
oldmansimek
Just started working on a buddies engine he told me that it was originaly out of a thunderbird, cant make alot of the 3's but there is a big S on the intake manifold.
Old Mar 24, 2006 | 03:10 PM
Redmanbob's Avatar
Redmanbob
I no guru here so ???? But as I understand it the GT will have a rather odd exhaust manifold bolt pattern. Unlike the FE basic one atop the other it has stagger to the bolt pattern. (More bolts per exhaust hole)
Old Mar 24, 2006 | 03:39 PM
FalconStng's Avatar
FalconStng
I believe the GT heads have 14 exhaust manifold bolts per side where the regular heads have 8 exhaust manifold bolts per side.
Tracy
Old Mar 24, 2006 | 07:12 PM
Bear 45/70's Avatar
Bear 45/70
Standard heads have 8 holes one each above and below the exhaust ports. The GT heads have the vertical holes and extra holes on the sides of ports. The standard manifolds are a straight log type (rectangle) where the GT ones kinda wiggle around and look like they flow better (they do). Thunderbirds never had a GT motor from the factory.
Old Mar 24, 2006 | 10:57 PM
oldmansimek
Thanks guys have to check it out there were headers on the truck so I couldn't say off the top of my head.
Old Mar 25, 2006 | 02:17 AM
fordraceboy's Avatar
fordraceboy
chances are pretty good unlrss it was a cusom set of headers that they weren't GT heads... i've seen only one set of headers that fit trucks with the 14 bolt pattern, and they were custom ordered(not built though) from stan headers.. JMO
Old Mar 25, 2006 | 06:51 PM
Barry_R's Avatar
Barry_R
'66-69 GTs had the 14 bolt pattern. Headers for the 16 bolt CJ will physically bolt on in most holes - - but the ports wont line up. Not good for power, but most guys don't know to check.
Old Mar 25, 2006 | 11:33 PM
oldmansimek
Thanks guys I checked the exhaust ports and they are the standard two per port over and under
Old Mar 26, 2006 | 12:24 AM
Bear 45/70's Avatar
Bear 45/70
The GT motors were not stock in the T-birds, only the Fairlane body styles and the Mustangs.
Old Mar 26, 2006 | 03:36 PM
baddad457's Avatar
baddad457
Only thing that set the GT 390 apart was the staggered exhaust pattern and camshaft, other wise it's really the same engine the bigger cars got. The 390 in my 68 Merc Monterey's got the same heads, (minus the staggered pattern), same comp ratio pistons, same block, crank , rods etc. Only this one got a 2 bbl intake and carb at the factory. The camshaft & Holley carb made the difference in the power rating on the GT.
Old Mar 26, 2006 | 03:43 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
The real reason for the extra bolt holes was chassis clearance on the smaller cars. The over and under bolt pattern would not have cleared the shock towers in the center. If anyone has ever changed plugs in either a 390GT or CJ you know what I mean about tight clearance. Ford also designed the CJ exhaust manifolds to flow better than the old log style, the only better cast iron manifolds for FE engines were the 406-427 style. Some 390 heads had the bosses cast for the extra holes, but not drilled and tapped.
Old Mar 26, 2006 | 03:57 PM
baddad457's Avatar
baddad457
Originally Posted by 85lebaront2
The real reason for the extra bolt holes was chassis clearance on the smaller cars. Some 390 heads had the bosses cast for the extra holes, but not drilled and tapped.
Right. I've got several sets of C8AE-H heads that all have the bosses. One set is drilled and tapped for a Stang/Fairlane all the others have the vertical pattern. The D2TE heads also have the extra meat for the GT pattern.
Old Mar 26, 2006 | 04:11 PM
Bear 45/70's Avatar
Bear 45/70
I found on both the GT and CJ motors (I had a couple of both) that a 3' extension with a universal on it (I had one with the universal built in) made it a snap to change the plugs (mainly 7 and 8). The extension put the wrench above and outside the fender and I never dinged a knuckle again.
Old Mar 26, 2006 | 04:14 PM
baddad457's Avatar
baddad457
Also handy is a 13/16 spark plug socket thats got wrench flats on the extension end.
Old Mar 26, 2006 | 07:50 PM
85lebaront2
Trust me, I learned all the tricks. I used to own a tune-up and carburetor shop. I still have a 24" 3/8" drive extension I bought for big block Mustangs and intermediates. The worst were the 4 speed models with air pumps.
