help
Old Mar 24, 2006 | 12:00 PM
rutherfordhyd's Avatar
rutherfordhyd
help
i traded for a 96 f-350 xlt powerstroke. drove it one day and it cut off and has yet to start. had it scaned and showed code p1128 injector driver module bought reman nothing replaced cam sensor nothing replaced pcm nothing replaced seliond on oil pump nothing replaced mec. fuel pump and checked all fuzes any body got any sugestions
Old Mar 24, 2006 | 06:35 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Try and give us some details on what the truck is doing.
Does it turn over at all?
Does it smoke while trying to start?
Have you checked all of the fuses? In cab and under hood?
Do your glow plugs activate?
Is it spinning over FAST or SLOW?
The more information that you can give about the symptons, the better we can help.
Old Mar 24, 2006 | 06:37 PM
1997F-350's Avatar
1997F-350
plug in the block heater and try to start it.
Old Mar 26, 2006 | 12:34 PM
14psd's Avatar
14psd
Talking
MORE info pls. This forum will give you some great advise so please give us more and we will help ya!
Old Mar 27, 2006 | 05:41 AM
bilder12's Avatar
bilder12
if you plug in the block heater, it will take about 2 hrs to heat the water jacket for starting. Also, if cranking slow, charge the batteries individually. The power strokes use lots of electrical power to get going. You also want to make sure that you got the right cam sensor, somewhere there was a change up in part numbers.
Old Mar 27, 2006 | 07:05 AM
rutherfordhyd
new set of batteries turns over real fast. does not smoke went trying to crank its like the injectors are not firing. truck was running real good when it just died. checked all glow plugs checked good even bypassed glow plug relay didn't work. checked for codes nothing showed. thanks for any help
Old Mar 27, 2006 | 06:40 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Are you sure all the fuses are good? Sounds like the fuel heater shorted.
Old Mar 27, 2006 | 08:58 PM
1997F-350's Avatar
1997F-350
do you get a wait to start light when you turn the key on? if not check maxi fuse #22 under hood. if blown unplug fuel heater and replace fuse.
or is your tach registering while cranking over?
or do you know someone who you can try there idm out of there truck?
Old Mar 28, 2006 | 06:58 AM
rutherfordhyd
i've checked fuzes ok checked oil pressure on high pressure oil pump 25 psi it has been changed before it had a reman sticker on it .are there lots of problems with these.i know it needs 500psi to crack the injectors.thank guys
Old Mar 28, 2006 | 08:38 AM
Kwikkordead's Avatar
Kwikkordead
Before you throw a new HPOP at it, pull the IPR valve and see if it's blown an o-ring.
Old Mar 28, 2006 | 08:48 AM
rutherfordhyd
i've change the ipr valve out of a run vehicle nothing. this truck is driving crazy. checked voltage at ipr 12.4 volts
Old Mar 28, 2006 | 08:55 AM
Kwikkordead
Ok, you've mentioned only 25psi at the HPOP.
Old Mar 28, 2006 | 11:23 AM
1997F-350's Avatar
1997F-350
are you sure you are not meaning fuel pressure here rutherfordhyd?
how did you check the hpop pressure?
Old Mar 28, 2006 | 12:03 PM
rutherfordhyd
tied into lines off oil pump at heads. i never thought a diesel would be this bad but to late to turn back now. thanks
Old Mar 28, 2006 | 02:29 PM
1997F-350's Avatar
1997F-350
did you dead head the pump?
what i mean is disconnect both hpo lines at the head from hpop that go to hpo rails. cap one of them and install a gauge on the uncapped line. if you only did one side you may have a bad injector oring on the other side letting all your oil get by. i would test pressure this way to be sure.
if so and it was bad i guess you know what you need to do. if it was me i would buy the """crm 17*""" pump and put that on instead of a 15* stocker. just my .02
