CPS Failures
Old Apr 30, 2006 | 05:54 PM
  #61
buckywill's Avatar
buckywill
ok I am new to this sight I have had this truck for 3 months is this CPS covered under 100,000 warrenty, what is the CPS price and where is it located and what do i need to change it thanks fred
Old May 2, 2006 | 12:41 AM
  #62
ramsmoker's Avatar
ramsmoker
Talking Cps
Welcome my friend. Yes the CPS is a covered item. I bought my backup unit on e-bay for $50.00. The deductable is $100.00 and it isn't a bad job to do yourself. Its on the front right side of the engine. You will need a 10mm wrench and a screwdriver to help break it loose.
Old May 2, 2006 | 12:59 AM
  #63
Tenn01PSD350's Avatar
Tenn01PSD350
Yes welcome Fred, check here regularly for solutions to problems and before you know it, ways to spend some big money. It's called PMS: Powerstroke Modification Syndrome.
Old May 2, 2006 | 03:46 PM
  #64
davyjac's Avatar
davyjac
CPS or something else?
I have some serious intermittent hessitation problems with my 1999 F350 Diesel. When letting off the throttle completly, and then trying to accelerate, the check engine light will come on and there will be no response when applying the throttle.
I did some research on Alldata, and discovered what I think may be another possible cause for hesitation. It's called the "Accelerator Pedal Position Sensor". It's located at the top of the accelerator pedal assembly.
This has happened even while on the highway. The no throttle response can last for up to ten seconds or more. So far anyway.
So I reseated the connector on the peddal position sensor, and took the truck for a test drive. I had no problems, but like I said the problem has been itermittent.
I have an electronics background. Through my experiance I can definatly say that dirty or oxidized connection can cause a lot of problems. This is espesally true with low energy signal circuits.
I think the idea of cleaning and protecting the connection will probably help the problem in a lot of cases.
Davyjac
Old May 2, 2006 | 05:50 PM
  #65
zx250's Avatar
zx250
Of the next Riffraff East
Davyjac
The TPS connections can be cleaned and in my case it did seem to help. I never got the Check Engine Light on mine nor did I get it on my CPS failure. While it won't hurt the clean you connections on the TPS, I'm not sure that will solve you problem. If you CEL light came on then a trouble code has been stored in the computer. You need to find out what that code is and go from there. Most auto stores will do the scan for free. I know around here Autozone, Advance Auto and some others will. They probably can't interpete what the codes mean, but some one here will understand and help you with it. The CPS usually don't throw a code and I don't think the TPS will. I believe your problem is somewhere else, all though the problem that is tripping the CEL may be originating from you TPS.
Have your codes checked and let us know.
Welcome to FTE.
Old Jun 2, 2006 | 12:24 AM
  #66
the weez's Avatar
the weez
I'm totally on the bubble of should I replace my cps or not. I haven't had any problems at all but it was factory installed in '97 and now has 122k on it. Is changing it before it goes good preventative maintence or just worrying over nothing.
I'm also a little confused about all the talk about lube's and sprays. Are we just talking about that little tube of white grease or is it something else?
Old Jun 2, 2006 | 06:35 AM
  #67
kawika's Avatar
kawika
I would leave it on, but get a spare just in case. Why mess with one that seems to be working. Also since it has been in so long. It may be a b!#ch to get out. If you do change it out, remember to lube the gasket before you replace it so that it will be easiere the next time around
Old Jun 14, 2006 | 08:58 PM
  #68
spunout's Avatar
spunout
Ok I had all the signs of a bad cps so I took the advice and disconnected and reconnected the cps a few time. I think it made it worse so I ordered the new CPS (black) off of ebay for about $55 brand new in pkg. Replaced it about a week ago and I have not had a problem since. Thanks for all the info guys.
Old Jun 18, 2006 | 06:31 PM
  #69
AlaskaF350PS's Avatar
AlaskaF350PS
I'm new to the site, and some of you may have seen my thread posted about a week ago asking for input on my truck dying and the garage charging me $900 to replace the CPS. Truck is running fine now, but one thing confuses me--what is the difference between the "blue" CPS and the "black" CPS? Also, since Pop pointed out that the Ford CPS sensor is a low-bidder item, which brand do you suggest? After my problems, I'm putting a spare behind the back seat alongside the spare oil, fuel and air filters, so I want to have a good quality one. Sorry, Pop, I would have sent my supposedly "bad" sensor if the garage had a policy of returning bad parts upon repair. I usually have to twist their arm to get ANY part back. Also, just for your information as you pursue your quest, my CPS supposedly DID throw an ECM code, P0340, according to the invoice from the garage.
Given the wide range of possible hesitation/dying problems (mine died after engine reached what seemed to be excessive heat), what other parts do you suggest I keep spares of on hand?
Thanks. You guys are great and the wealth of knowledge and support is great here!!
Kevin
Old Jun 18, 2006 | 06:42 PM
  #70
bigred2003's Avatar
bigred2003
Another CPS casualty, a 03 with only 35,000 miles on her. No moist conditions and no excessive heat. My son and I pulled out onto a highway last week and almost got creamed. It will be under warranty and will be at the dealer this coming Wednesday. What does it take to get a recall as I can't count how many people that I have heard the problem from.
Old Jun 18, 2006 | 06:45 PM
  #71
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Kevin
the "blue CPS" is from an International DT466 engine. it has a much stronger magnet in the sensor. so therefore some say the signal is much stronger, and, it will help fuel mileage, power, faster startups, etc. this will void any questions about fixing a CPS problem under warranty if you do the blue route. when this first started getting hot a few months ago, users were having CPS problem just a few hundred miles after the CPS install. they went back to a black one, and then no more problems. DP Tuner programs it's tunes for a Black CPS, and some say that it will not run as it should with a Blue CPS.
i would keep a 10mm socket and ratchet with the CPS at all times, as that is what it takes to change it.
Old Jun 18, 2006 | 06:49 PM
  #72
PSNut's Avatar
PSNut
I think Ford is in denial.
Nut
Old Jun 18, 2006 | 09:19 PM
  #73
RAMPAGE_F350's Avatar
RAMPAGE_F350
I finally gave into the hoopla about this CPS situation and bought a Blue CPS from Garett. Even though my stock black CPS is fine, I intalled the blue one anyway. The idle seems smoother and I could swear the engine sounds quieter. We"ll see if the blue holds up. The good thing about this whole thing is I have a spare in the glove box.
Old Jun 18, 2006 | 11:14 PM
  #74
ernesteugene's Avatar
ernesteugene
If the CPS connector is the problem, why don't other connectors from all the other sensors cause similar problems? I replaced my CPS only to find that my problem was due to a loose pass-through connector inside the valve cover leading to the injectors.
Old Jun 18, 2006 | 11:52 PM
  #75
Chance_Thomas's Avatar
Chance_Thomas
I stubbled on a website last week that was used for reporting bad CPS issues. I can't find it but it was on the edge of being a class action.
