CPS removal
Old Mar 24, 2006 | 10:37 AM
claydr54's Avatar
claydr54
CPS removal
I'm trying to replace my CPS. Of course there is an altinator in the way. My problem right now is; I just twisted my 1/4 to 3/8 adapter off. This not left hand threads is it and if not, has anyone twisted the bolt off at the block? It is plenty tite!
Old Mar 24, 2006 | 10:52 AM
bilder12's Avatar
bilder12
never saw one with the alternator in that position and never saw one that tight. You want to be working in the area of the timing mark indicator. The only thing that would be in the way is the fan belt crossing in front of the bolt head.
Old Mar 24, 2006 | 10:58 AM
Car_nut57's Avatar
Car_nut57
FTE *******
You should be laying on your back under the truck, passenger side of he harmonic balancer and you will see the metal indicator tab from the CPS. You will need a 3/8 drive 10mm socket with a short extension to get the rachet in a good place to turn it.
Old Mar 24, 2006 | 11:12 AM
claydr54's Avatar
claydr54
I am on my back and it is the CPS. My ford manual say's this alternator is there if you have dual batteries. Don't all PSD have dual batteries?
Old Mar 24, 2006 | 11:36 AM
SpringerPop's Avatar
SpringerPop
All PSD's have dual batteries, but the alternator is under there only if you ALSO have "dual" alternators. The location for the other one, (or only one if a single system) is on top of the engine.
Pop
Old Mar 24, 2006 | 11:40 AM
claydr54's Avatar
claydr54
Yeah, I read last night there is an ambulance special. There are no flashing lights on this one.
Old Mar 24, 2006 | 01:38 PM
kawika's Avatar
kawika
I have the dual alternators and it was tight quarters near the CPS. Used a 6 in extension to my 10 mm socket. The CPS bolt is regular threads and should come outwith out breaking the 1/4 in adapter. Just use a 3/8 ratchet, you may have had a broken adapter.
Old Mar 24, 2006 | 03:08 PM
claydr54's Avatar
claydr54
Gotter done, and it was tite! I suppose I'll get a blue one and swap them out some day I don't have anything better to do and want a little agony.
Old Mar 24, 2006 | 03:44 PM
Medic 66's Avatar
Medic 66
Duals are for the ambulance prep pack too
