Fuel inline bypass valve
Old Mar 23, 2006 | 09:40 PM
Iron Horseman's Avatar
Iron Horseman
I have a 95 with a 320. My question is does this pressurized fuel system have a bypass for the fuel to by pass when the vehicle goes from directly underload to idle? Or is this checked up by the pressure regulator? Please pasrdon my fundamental questions. I'm still learning my truck. Thanks, David.
Old Mar 23, 2006 | 09:56 PM
edwardo's Avatar
edwardo
the fuel that does not get injected into the engine go back to the tank in a return line.
Old Mar 23, 2006 | 10:38 PM
Iron Horseman
I that line regulated someway or is it just an open line?
Old Mar 23, 2006 | 10:44 PM
edwardo's Avatar
edwardo
there is a regulator that is vacuum controlled.it keeps the pressure up for the injectors.some people leave the vacuum disconnected to keep fuel pressure up all the time.
Old Mar 23, 2006 | 10:49 PM
Iron Horseman
Unhappy
The reason I ask this Edwardo, is because my 95 seems to want to run out of gas as stops ans starts. Plus under a load. Like up hill. I've ruled out the pump, filters and pressure regulator. They're all new. Along with almost everypart under the hood. lol. This is why I figured it could be something as simple as this. Hoping anyway. I even pulled my dist. and installed a new stator and set my timing from scratch. Loads more power because it must have been off. And I replaced the control module. I'm lost as lost can be.
