ASAP Hellwig swaybar New Style
Old Mar 23, 2006 | 09:17 PM
raptor05's Avatar
raptor05
I have almost everything in place. Just a question about the screw part that drops down from the frame. What stops the sway bar from moving up this piece. I noticed on the older style with the links it looks like it is bolted in place. Please help.
Old Mar 23, 2006 | 09:38 PM
raptor05's Avatar
raptor05
I figured it out I am missing the metal sleeves that go over the piece that hangs from the frame. I sure wish I found this out earlier. I guess I will try and call Hellwig in the morning and see if they will send me some.
Old Mar 24, 2006 | 05:15 AM
Bob Gervais's Avatar
Bob Gervais
If you're in a real bind and Hellwig is going to take too long to ship out the sleeves, you can also use a piece of pipe, like a close nipple or something like that. With the truck on the ground, and the swaybar level, measure the length of pipe you need, cut to fit and install. Sure, Hellwig should have included them, but this won't be expensive and it'll save you from having to take the bar off and reinstall it when you get the sleeves.
Old Mar 24, 2006 | 06:59 AM
SledHauler's Avatar
SledHauler
My Hellwig kit was missing several nuts and washers. I e-mailed them the next day. They answered the day after and then sent the parts regular mail. Took nearly a week to have them in hand. I had already used other parts and had it all together, but it was still a bit irritating. Maybe getting someone on the phone would give quicker results.
Old Mar 24, 2006 | 07:28 AM
Bob Gervais
A little disappointing to hear about their hardware issues. Of course, checking all the parts to make sure you have everything before installing stuff is a great idea, but I usually assume everything is there, and can't wait to get the part installed.
If/when I get a Hellwig bar, I'll make sure to check the hardware first.
Old Mar 25, 2006 | 01:22 AM
ymmv's Avatar
ymmv
Hellwig is no better or worse than almost all the OEMs. Even the most expensive Porsche stuff can still show up with chipped paint or missing/wrong pieces. The only thing to do is pre-assemble the given kit and eye-ball the job. This also comes under the "read the instructions first" rule, which, as we all known, just never happens.
Old Jun 24, 2006 | 11:00 PM
RubenG's Avatar
RubenG
Raptor05,
How did you do step #6 on the hellwig installation?
it talked about removing the emergency break bracket?
Do you have a detailed picture i could follow.
I tried installing it but this is the only thing i need to do.
Thanks
RubenG
Old Jun 29, 2006 | 03:07 PM
mistletoelicker's Avatar
mistletoelicker
Just thought I`d butt in, my x has a rear sway bar already, i`m sure its stock??? will the Hellwig still cure the tracking problem??
Old Jun 29, 2006 | 04:16 PM
aklim's Avatar
aklim
Originally Posted by RubenG
Raptor05,
Thanks
RubenG
I might have the pic in my gallery. Think of it this way. Bolt first. Washer goes thru bolt, bushing, washer, brake cable holder, 1 more washer and then frame. Stopped by a lock nut and another nut just to be safe.
Old Jun 29, 2006 | 06:53 PM
turboale's Avatar
turboale
I am still waiting for my bar but if it doesn't cure it, it should help out quite a bit. Plus it should leave you with a feeling of more control over the vehicle. You might have a bar (most do these days) but the helwig bar is thicker ie stiffer ie less body roll. If you have major wander I would start with radius rods first, then go to the helwig bar if wander is your first concern. If you want more control and to take care of most of the wander, get the sway bar.
Old Jul 3, 2006 | 03:59 PM
Floundered's Avatar
Floundered
I finally installed the Hellwig bar on my 4x4 'X last night, after getting my own bolts & washers. I didn't put a washer between the brake cable holder and the frame because to do so would make the head of the bolt stick out above the leaf springs.
The gap between the frame rail and the leaf springs is almost exactly the same as the width of the upper eye-bolt mount (the one with the hourglass bushing) for the rod, once the brake cable holder was added in. I pondered finding a different place for the cable holder, but it just barely seems to work as is. If that part of the spring defects up by a few millimetres, it would have hit the head of the bolt.
Anyone else have this problem?
Old Jul 3, 2006 | 10:21 PM
aklim's Avatar
aklim
Thanx to all of you who raised the question, I checked the brake cable side. Guess what, one of the square U bolts of my radius rod was rubbing on my Hellwig sway bar. Took it all out and forgot about the brake cable loop. There are enough back there to keep it in position and now everything should not rub. The U-bolt was partially worn out by the steel washer which was bent and some of the bushing is worn out. Not critical areas tho.
Old Jul 4, 2006 | 07:01 PM
mistletoelicker
I guess I`ll start with the redius rods...I would say mine is a severe wandering problem..thanks
82racin
Aug 16, 2011 11:36 AM
brownie83
Mar 6, 2009 08:02 AM
Wieckster
30
Nov 15, 2008 08:17 PM
RubberDuck
20
Dec 31, 2006 04:42 PM
