95 Bronco in line fuel filter quick disconnect question
So I thought Id do a little PM and replace the in line fuel filter on my 95 Bronco (351). The book wasnt clear on how the "quick disconnect" fittings disconnect and I basically ripped the old filter out of the fittings. When I did this some interesting little metal retaining pieces came out too - not without a little help however.
So now I have these quick disconnect fittings that the new filter just slides in and out of easily. I re-installed the metal clips that snap over the fuel line and fuel fitler tubes but these really dont look like they serve any purpose. Also the white plastic retaining clips that came with the filter seem equally useless.
So what Id like to know is did I destroy the quick disconnects or is there something Im missing about the plastic horse shoe shaped clips that came with the filter.?
Im feeling rather discouraged having been beat by a fuel filter and also taking a significant hit on the nose with a mag light in the process. Any help would be greatly appreciated.
Originally Posted by Alta
So what Id like to know is did I destroy the quick disconnects or is there something Im missing about the plastic horse shoe shaped clips that came with the filter?
[QUOTE]I re-installed the metal clips that snap over the fuel line and fuel fitler tubes but these really dont look like they serve any purpose.
Those are a safety thing that Ford added after some recalls back in the 80's. All they do is keep your fuel lines from spraying all over the place in the event of a connector failure.
As as far as the fittings go, you might have just ruined the garter springs. They're the same ones that A/C lines use, so most parts stores have them. Just get the right size. Cheaper than trying to replace a fuel line.
sounds good - I'll track down the garter springs - Ive learned a lot on this little job - I dont know why they ad tocomlicate everylittl part on the vehicle - it is just a fuel filter! After rebuildng a dozen or so engines over the years, seting up diferentials, fixing transmissions, and dong frame up resoratons, I really thought I could handle a fuel filter....sheeeeeesh!
