Sponsored by: Real Truck
Rookie question on leveling kits
Old Mar 23, 2006 | 01:24 PM
Milwaukee,WI's Avatar
Milwaukee,WI
I'm thinking about doing a leveling kit on my 06.
How hard is it to do yourself? I've got access to an autoclub with every tool and lift in the world, so the right equipment won't be a problem?
Are there different kinds of kits? Any easier to install than others?
What about sizes... If I can't go 2" because of clearance in my downtown parking garage and at the airport... Do they make 1" leveling kits? Or is that pathetic to go thru the trouble just for an inch?
Does the raised front affect fuel mileage at all?
Old Mar 23, 2006 | 07:04 PM
EnviroCon's Avatar
EnviroCon
None of the levelling kits are difficult to install. Time consuming, but not that difficult. And those autoclub shops are usually staffed with people that can help out a little.
You basically have 2 choices. New springs kit and a spring spacer kit. If you go the new spring route, look for a kit that comes with alignment cams. Both kits are about the same in terms of installation ease.
No 1" kits, sorry. But, there is an easy way to level your truck and keep your roof. Instead of raising the front, lower the rear with new blocks.
No.
Old Mar 24, 2006 | 03:42 AM
V10man's Avatar
V10man
check here for most of the available kits
http://www.rockymountainsusp.com/fd4_05f2_350.htm
Old Mar 24, 2006 | 07:03 AM
EnviroCon's Avatar
EnviroCon
I stand (sit typing) corrected. Skyjacker now has a 1" kit.
