Tap on rebuilt
Old Mar 23, 2006 | 12:37 PM
fordflaresides's Avatar
fordflaresides
Tap on rebuilt
I have a rebuilt 300 in my '73. If I give the engine a rev and let off the gas it taps for several seconds. It just started doing this today, what could this be?
Old Mar 23, 2006 | 01:15 PM
miichael's Avatar
miichael
it taps after you let off or it taps when you rev it? Did you adjust your rockers correct?
Old Mar 24, 2006 | 01:36 PM
fordflaresides
after you rev it and let off, maybe it's just the hydraulic lifters.
Old Mar 24, 2006 | 02:12 PM
quicklook2's Avatar
quicklook2
adjust rockers
proper oil level and viscosity?
motorcraft oil filter?
Old Mar 24, 2006 | 09:29 PM
fordflaresides
Rockers were adjusted to spec., 7 qt. 10w30 Motorcraft Oil (Deep Rear Sump Pan), STP Filter (Used on 1978 300 w/o problem). Motor is a 1984 Completely Rebuilt 300. New rockers, springs, pushrods, bearings, pistons, rings, valves, etc. All that was reused was the bare block & head. Compression 140-145psi at 2500 ft of elevation.
