Bronco II Ford Bronco II
89 2.9 stumbles on acceleration
Old Mar 23, 2006 | 09:40 AM
ira551's Avatar
ira551
I have a 89 Bronco II 2.9 fuel injected v-6, when I accelerate it stumbles and falls on it's face. If I let off the gas and slowly add more pedal it will do fine but if you add pedal to fast you will get ahead of it and can feel it start to nose over. You can then let off the gas slightly and try it again as long as you don't get ahead of it. I have run the codes and come up with nothing. I originally had some fault codes replaced defective sensors etc. but have no fault codes at this time. I have checked the fuel pressure it is within range of the bulletin Ken supplied. The engine will not rev up during a WOT(wide open throttle) test either, if stumbles and if you hold the pedal down will just cough and stumbles. Any ideas on where to go from here? Thanks ira551
Old Mar 23, 2006 | 11:38 AM
mrshorty's Avatar
mrshorty
going to assume this means all pass codes.
How thorough of a fuel pressure test did you do? Did you rev the engine while you had the fuel pressure gauge on it to make sure fuel delivery was keeping up with engine demand? Might even be worth the effort to arrange it so you can monitor the fuel pressure under load. Have you checked for raw fuel in the vacuum line to the FPR?
Have you put a vacuum gauge on it to see if the exhaust is plugged?
There are a few ideas, I'm sure others will have different ideas, too.
Old Mar 23, 2006 | 02:48 PM
ira551's Avatar
ira551
Mrshorty we checked the fuel pressure and it held steady at idle and reving the motor. Just replace the FPR and did not have fuel in Vacuum line. Ran vacuum test on engine and is running at 17" of vac and steady.
Old Mar 23, 2006 | 07:40 PM
Ken00's Avatar
Ken00
To add to mrshorty's thoughts....
What was the fuel pressure?
Whats the timing with the spout pulled?
Have you checked for vacuum leaks?
Old Mar 23, 2006 | 11:58 PM
ira551's Avatar
ira551
fuel presure was 30+ psi have not done timing because it has never been touched to my knowledge.
Old Mar 24, 2006 | 12:22 PM
kernel-panic's Avatar
kernel-panic
The fuel pressure should be 35+ -minimum- and I would go ahead and check the timing with the spout pulled and check for vacuum leaks. The FPR may be -working-, but it sounds as if there is either a vacuum leak, the fuel pump is going out, OR your catalytic converter/exhaust is stopping up.
"How can you -not- notice a man sticking a banana in your tailpipe??" - Beverly Hills Cop
Old Mar 24, 2006 | 06:56 PM
kernel-panic
Okay, just checked my timing and vacuum on mine warmed up. Timing with the spout pulled was @ 10 deg BTC with a little slack here and there, but pretty much dead on. Vacuum @ idle was 18-19 inches (which on my gauge is the low end of the "normal" green zone). I manually throttled up with my thumb on the linkage, slight dropoff, but fairly solid response and it shot up to 20-22 inches then steadied around 19-20. If, when you're checking vacuum, and it drops severely (10 inches or less), then you're going to have a lot of work ahead of you because something is blowing by and/or it's time for a new cam/timing chain set. I don't have a "hi-pressure" fuel injection pressure gauge... and I'm not about to try my dial-type air gauge, so, not sure what my fuel pressure is at *shrug*.
I would definitely check to make sure all the intake gaskets are tight and not leaking... and check every vacuum hose for cracks or pinholes, etc. and definitely pull your spout and check your base ignition timing.
Old Mar 25, 2006 | 12:22 PM
ira551's Avatar
ira551
reset timing to 10 Deg with spout removed made a big difference. Think I just need to fine tune it. Thanks for all the help..If I run into anything else I'll be beack.
Old Mar 25, 2006 | 07:58 PM
Ken00's Avatar
Ken00
Glad to hear it's running better!!!
Old Mar 27, 2006 | 03:04 PM
kernel-panic
Did this affect your vacuum at all or is it still 17 inches steady? Hopefully, it brought your vacuum up to the normal range(s).
Flavoade
17
Mar 28, 2017 12:53 PM
Injunction joe
1983 - 2012 Ranger & B-Series
May 16, 2016 09:40 AM
Biggyniner
Apr 12, 2016 09:31 AM
hdgapeach
33
Nov 24, 2015 12:59 PM
ira551
Bronco II
Mar 18, 2006 08:48 AM
