Sponsored by: Real Truck
Warm air when on vent
Old Mar 23, 2006 | 06:46 AM
Hotwheelbill's Avatar
Hotwheelbill
I have noticed that when my truck is set on just vent, outside air, it is always warm air. The other day it was in the 60's and the air felt like 80*. The A/C also does not blow very cold. I have a charge kit and plan to fill it today, if it needs it, but I think it goes back to the warm air problem. BTW I only have the factory temp. gauge now and it shows normal temp. New 203 therm and aluminum housing about 3 months ago.
Old Mar 23, 2006 | 05:02 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Thread moved
Old Mar 23, 2006 | 05:10 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
you directed me to this from the other forum- i think your problem is the coolant that flows through the heater core when the heat or AC is on. look at this- and see if it is what you need.
From dieselsite:
"In a 1999-2003 Superduty(7.3L Powerstroke, V8 or V10) hot engine coolant is flowing through the heater core whenever the heat or Air Conditioning is turned on. The system does not differentiate between the two. This is fine when you are running your heater. However, running the Air Conditioner is a different story. When your AC is on, your cold air is not only flowing across the evaportator coil but it also flows across the heater coil which has hot engine coolant flowing through it. This results in a very inefficient air conditioning system in these vehicles.
This DIESELSITE Air Conditioning Control Valve will automatically shut off coolant flow through the heater core when MAX AC selected. The result is a decrease in duct temperature by 10 degrees or more which will be felt through your vent openings into the cab. This gets COLD!
Install takes about 15 minutes and requires no special tools. Everything you need is included in the kit. Full detailed instructions including color pictures are included. "
http://www.dieselsite.com/index.asp?...PROD&ProdID=21
Old Mar 23, 2006 | 05:24 PM
SpringerPop's Avatar
SpringerPop
Also directed here from the "other" forum.
In addition to the above, even though I personally DO have the above-mentioned vacuum-operated valve, if I were going to do it over, I would do what is very common among the OTR guys: just put a ball-valve in-line with one of the heater hoses. Not as "automatic", but you likely will only have to move the position of it a couple of times a season, at most.
And, the parts are available anywhere.
Pop
Old Mar 23, 2006 | 05:38 PM
jtharvey's Avatar
jtharvey
Guess, where I came from too???
Pop, you would do it differently, why? Mainly because of cost and a simpler system with a ball valve?
Edit: I remember Kwik posted something about moving the air intake location for the heater & A/C. As it is stock, it pulls from the drivers side, passes over the [hot] turbo, and into the cab. He blocked off that intake and opened up the passenger side intake. Search for it under threads started by Kwik.
Old Mar 23, 2006 | 05:44 PM
Hotwheelbill
From dieselsite:
http://www.dieselsite.com/index.asp?PageAction=VIEWPROD&ProdID=21
Thank you for your help. I will do this fix.....Florida! But would this still be the cause of the warm air from the outside air? This would,should, vent from outside the cab and not have anything to flow over.
I was just concerned about the engine temp. getting too high and causing this.
Old Mar 23, 2006 | 05:47 PM
Hotwheelbill
I'll look for it now. Thanks too, jtharvey.
Old Mar 23, 2006 | 06:41 PM
wlihntr's Avatar
wlihntr
i also think it has some to do with fact the turbo sits right under vent air intake and keeps it pretty warm
Old Mar 23, 2006 | 07:46 PM
Betthebux's Avatar
Betthebux
Pop
Gave you rep points for this one. Got everything I need just sitting around in the garage. Cant beat a free mod.
Old Mar 23, 2006 | 08:25 PM
Kwikkordead's Avatar
Kwikkordead
Good memory JTHarvey.
Here's the thread that I started. After some time has gone by I have found that it helped but not completly cured the problem.
https://www.ford-trucks.com/forums/s...d.php?t=459570
Old Mar 23, 2006 | 10:54 PM
SpringerPop
Reason I'd do it differently if I had to do it over again? I prefer "manual control", and there's less to go wrong.
Heck, I can find the hood release.
Ask Kwik how his glow plugs operate, and why....
Same reason.
Pop
Old Mar 23, 2006 | 11:31 PM
jtharvey's Avatar
jtharvey
I figured it was something like that. Now to just go get some brass ball valves before it starts getting hot around here. Do you happen to know what the ID is of the heater hose running into the cab?
Old Mar 24, 2006 | 12:17 AM
SpringerPop
Virtually certain it's the standard 5/8" heater hose.
Pop
Old Mar 24, 2006 | 05:04 AM
Hotwheelbill
Thanks kwik, I will work on this one this weekend!
Also thank eveyone for coming over to help!
Old Mar 24, 2006 | 11:35 AM
jtharvey's Avatar
jtharvey
Pop
Thanks Pop. That's what I was thinking, but didn't know for sure. It looks smaller than 3/4" though. I just didn't want it to be some really strange size.
