window crank gears
Old Jan 1, 2003 | 12:17 PM
MufassaMaxx's Avatar
MufassaMaxx
window crank gears
The drivers side window on my 67 has always been tough to use but now that i took it apart it turns out to be broken. the gears that goes from the window crank to the curved gear that lifts the window, is in several pieces. Where can i get one? or could i attempt to weld mine back together? i don't need an entire regulator but just this little piece, and also don't have the money to buy the whole assembly. if anyone has what i'm talking about please e-mail me.
Thanks
Nate
Old Jan 1, 2003 | 06:28 PM
flyboy2610's Avatar
flyboy2610
window crank gears
Go get one out of the junkyard.
Old Jan 1, 2003 | 07:26 PM
Mike W's Avatar
Mike W
window crank gears
I have swapped the little gear from another window. Think I had to drill out some rivets. There are probably several models that are identicle.
Old Jan 2, 2003 | 07:04 AM
StockMan's Avatar
StockMan
window crank gears
[FONT COLOR="#0000ff" SIZE="3" FACE="Veranda"]
These are dangerous in my opinion to work on, so be careful of that spring in there. I read a thread here several months ago talking about using the parts out of a passenger side regulator. I do not know how good that info is. As for a part source, I do not believe Ford designed these to be serviceable, so I am not aware of any source for parts on these.
[/FONT]
https://www.ford-trucks.com/dcforum/User_files/StockMan/flag.gif
[FONT COLOR="#ff0000" SIZE="+2" FACE="Signature"]Thom [/font]([FONT COLOR="black" SIZE="+1" FACE="arial"]aka StockMan)
[FONT COLOR="#0000ff" SIZE="3" FACE="arial"]
[LINK:www.67fordtruck.com|1967 F-Series Registry]
Old Jan 2, 2003 | 10:29 AM
rebocardo's Avatar
rebocardo
window crank gears
If you could find that gear, it would be a servicable part. It is fairly easy and safe to remove. I have not had time to hit the junkyards, but, I think a power window motor gear might be kludged in. I have searched the WEB for the gear and could not find it.
The problem is its size, at 3/4 of an inch tall and about that wide, its tough to find.
Old Jan 2, 2003 | 06:13 PM
mk's Avatar
mk
Post window crank gears
I have discovered that the 67-72 regulators all interchange. Found this out when dismantling a 67 last summer.
mike
Old Jan 3, 2003 | 09:22 AM
StockMan's Avatar
StockMan
window crank gears
Good point MK. 67's are unusually unique (that might be redundant), but thankfully, there are at least a few parts which will interchange between the 67-72 series.
Old Jan 3, 2003 | 12:15 PM
BB's Avatar
BB
window crank gears
I thought the '67 regulators were different than the '68-'72, at least they look different and have a different part #. Are they totally interchangable or just some of the pieces?
Barry
Old Jan 3, 2003 | 01:41 PM
mlf72f250's Avatar
mlf72f250
window crank gears
I think the interchange manual lists '67 all by itself and '68-'72 together.
I fixed my '72 by taking good internal gears from the passenger side of a '72 junkyard truck. There is a thread on this board by onefine69 that details the process.
--Matt
1972 F250 Custom Sport Camper Special 4x2 360 2v C6 3.73
Some day hope to shorten to a 104" wheelbase as part of a Broncification project
My FTE Website -- http://www.clubfte.com/users/mlf72f250/index.html
My Galleries -- https://www.ford-trucks.com/user_gallery/displaygallery.php?userid=1108
Old Jan 3, 2003 | 01:47 PM
mlf72f250's Avatar
mlf72f250
window crank gears
Here's a link that covers a couple of options for the later ones:
https://www.ford-trucks.com/dcforum/DCForumID73/2308.html
--Matt
Old Jan 3, 2003 | 06:29 PM
mk's Avatar
mk
Barry, I put a 71 regulator into a 67 door and it works fine.
mike
Old Jan 3, 2003 | 11:03 PM
BB's Avatar
BB
window crank gears
Thanks a lot Mike and Matt, great info!
Barry
Old Jan 3, 2003 | 11:10 PM
BB's Avatar
BB
window crank gears
