thanks for the help
Old Dec 30, 2002 | 05:37 PM
oldiron's Avatar
oldiron
thanks for the help
Old Jan 1, 2003 | 07:26 PM
Lobuck76's Avatar
Lobuck76
thanks for the help
hey, i just signed up on this but iv'e been reading the tech articles
for awhile.
i just put power steering on my 70 f100. a task made much simpler
by reading several really informative tech articles on the subject on
this site. i just installed a 351w with an aod transmission, getting
that flanged up, today it was trans crossmember and shifter linkage.
next will be driveline issues. any advise on that would be appreciated.
keep up the good work rq
Old Jan 2, 2003 | 07:46 PM
flyboy2610's Avatar
flyboy2610
thanks for the help
Welcome to FTE!
I assume you are going to have your driveshaft shortened or replaced completely? My advice would be to have it taken to a good driveshaft shop. They can take all the measurements. Make sure they install greaseable U-joints. I don't like those 'permanently lubed' ones.
It would probably not be a bad idea to replace your suspension bushings.
Old Jan 3, 2003 | 07:18 PM
Lobuck76's Avatar
Lobuck76
thanks for the help
the driveshaft is gonna need to be apx 3" shorter. is there an advantage to the two piece drive line? i may have a one piece in my goody pile that i could have modified.
i replaced the i-beams , steering linkage with stuff from a low mileage doner truck.replaced bushings same time.
power steering box, column came from same truck.
i replaced the seals in the gearbox. i guess we'll see how bad it's gonna spew fluid.
i understand the adjustment on the kickdown rod is critical for longevity, i installed an aod trans out of 80 lincoln mark.
i guess i'll be studying up on that
thanks for the input,rq
Old Jan 4, 2003 | 02:19 PM
flyboy2610's Avatar
flyboy2610
thanks for the help
I think you'd be fine with a one piece shaft.
Have fun with your truck.
Old Jan 4, 2003 | 05:34 PM
jowilker's Avatar
jowilker
thanks for the help
I went to the one piece when I converted to auto.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member 0004 since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
