speedometer gear
Old Mar 22, 2006 | 07:40 PM
richard jobe's Avatar
richard jobe
speedometer gear
help where can i get a speedometer gear 1950f1 4sp(granny gear flathead)
its metal not plastic 22 teeth thanks richard jobe
houston freeways life&limb
Old Mar 24, 2006 | 09:38 AM
bigwin56f100's Avatar
bigwin56f100
Just bringing it back up to the top for you. I dont have one and I have no idea where to send you to get one.
Kevin Bigwin
Old Mar 24, 2006 | 10:18 AM
51ford fan's Avatar
51ford fan
I sure wish you had asked this question two weeks ago I had a scrap hauler come by and pickup two 51 4 speed trannys. The wife flat told me to clean up the back yard or I would be sleeping in my F1. Thought long and hard about it, but decided that cab is a little too narrow to sleep in comfortably.
Rod 51F1
Old Mar 24, 2006 | 10:22 AM
StevenK's Avatar
StevenK
Just hitchiking here. When I got my 52 f2 the speedo worked, but not the odo. Now the speedo doesn't work either (both in the truck and at the beach) Is this my cable or gear? If it's the gear - I'll be looking forward to the answer to Richards question.
Old Mar 24, 2006 | 11:08 AM
barry's Avatar
barry
If one part of the speedo stopped (odometer) then the speedo itself stopped, I'd suspect the speedo head itself. These are notorious for going bad. If both failed at the same time, then I'd suspect the cable or gear. They usually will make noise from the head. You can still find NOS gears if that ends up being the culprit, but I'm leaning towards the head being bad.
Barry
50 F-1
Old Mar 24, 2006 | 11:56 AM
51ford fan's Avatar
51ford fan
Just pull the speedometer cable housing off the back of the speedometer unit under the dash. Then drive the truck and see if the cable is turning or not, if it is, itsn the dash unit. If not, it's a broken cable or drive gear. My speedometer works fine but the odometer never has worked. One of these days I will get around to tearing the unit apart, or pickup a replacement
Rod 51F1
Old Mar 24, 2006 | 03:16 PM
B/B ford's Avatar
B/B ford
Clean & Classy
I would try United Speedometer Service, Inc.
It,s located in Riverside Ca. (it has a web site but don,t know if I can post it)www.speedometershop.com I,ll try.
Old Mar 24, 2006 | 06:02 PM
46yblock's Avatar
46yblock
If it ends up that the cable needs to be replaced, your local speedometer shop can handle the job. I just picked up a new cable and housing to fit a flathead 3 speed and Autometer speedo from the local outfit here. Cost was a reasonable $40. Even though he put it together from scratch, he did it while I waited, about 20 minutes.
Old Mar 24, 2006 | 09:25 PM
nixer's Avatar
nixer
Rod 51F1
sometimes a man just needs to let a woman know where she stands. hopefully you have a nice lumbar seat in that truck
