electrical
Old Mar 22, 2006 | 11:13 AM
RICHMC54's Avatar
RICHMC54
Question electrical
I've slowley been putting back together my 68 f-100 swb. Frame off. Yesturday I hooked up the battery to make sre the heater fan was working.
Nothing.It was like no battery at all. new battery, wiring is hooked back the way it was before I took it apart.Any prticulors I should be looking for.
Old Mar 22, 2006 | 12:12 PM
robins79 custom's Avatar
robins79 custom
Check all your grounds.
Old Mar 22, 2006 | 05:06 PM
jjblack's Avatar
jjblack
I agree with the grounds. You didn't say if the engine was in yet, There should be a ground strap from the cab to the engine and from the engine to the battery. With the frame off resto, did you paint, Paint makes a good insulator of grounds.
Old Mar 22, 2006 | 10:22 PM
1972ford_f-100's Avatar
1972ford_f-100
check ur fuses too
