fuel pump pressure
Old Mar 21, 2006 | 09:06 PM
harleyjohn45's Avatar
harleyjohn45
fuel pump pressure
i use an electric fuel pump on my 91 idi 7.3. i cannot find what the pressures should be for such a pump. i plan on buying a new pump and stowing it in the tool box, just in case.
Old Mar 21, 2006 | 09:52 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Should be around 6 to 7 PSI.
Old Mar 22, 2006 | 05:40 PM
harleyjohn45
thanks dave, i knew you would know.
Old Mar 22, 2006 | 07:27 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I just bought a small pump to feed my big pump that I think would work perfectly for you. It's a Carter hi-po series pump that puts out 72gph at 6 psi. Cost about $50 through Summit. Part #P4070
Old Mar 22, 2006 | 10:30 PM
PLC7.3's Avatar
PLC7.3
The 6 psi is good but the 72 gph is about 50 gph to much for our system.
Normal lift pump.......
Carter pump #M60278
Pressure Rating: 4 lb - 6 lb
Gallons Per Hour: 23
