Bedliners?
Old Mar 21, 2006 | 08:17 PM
Danny_Ocean's Avatar
Danny_Ocean
Bedliners?
What is preferred for bedliners...the plastic "swimming pools" or sprayed in?
Old Mar 21, 2006 | 08:28 PM
ol gray mare's Avatar
ol gray mare
Sprayed on bedliners are the way to go. The plastic bedliners will move and will rub the paint off and if water gets under the liner and will rust.
Old Mar 21, 2006 | 09:47 PM
Zane M's Avatar
Zane M
Plastic will do the job, but ol gray mare listed the cons to using them.
I have a plastic one in my '83, and it will get yanked and replaced with a spray on when I get the truck painted.
Old Mar 22, 2006 | 06:31 AM
fellro86's Avatar
fellro86
The bedliner in my truck gets to stay, as it has already done it's damage. I had it off a while back, and there was no rust under there, but plenty of dirt. The side rails though have depressions in them all the way back, so in order to cover that up, I would have to use bed caps. Sprayed in will do a good job for you. Also, bedliners are slick, everything slide around in there for the slightesst movement, but from what I understand, the spray ins aren't nearly as slick.
Old Mar 22, 2006 | 09:14 AM
white rose's Avatar
white rose
I just used a product called hippo liner, its a do it yourself paint in liner. I was very pleased with the results, a roller is supplied with the kit, the down side is you need two kits for a full size bed. Each kit cost about $70. I have half a kit left over which I plan to use under the fenders.
Old Mar 22, 2006 | 02:22 PM
StillaKilla187's Avatar
StillaKilla187
my plastic bedliner works, but if I had the money I would put a spray on in.
Old Mar 22, 2006 | 03:06 PM
robert collison's Avatar
robert collison
Does the spray in bedliner scrape off when you shovel dirt out of the bed?It also seems like your shovel would dig in sometimes and stick to it.A plastic liner lets a shovel go across it real easy.I have been thinking about a spray in also.
How will the spray in do to help the bed if it already has some rust in it.Will it help stop or should something be done prior to the spray.
Fat250
Old Mar 23, 2006 | 06:20 PM
1980_f_100's Avatar
1980_f_100
lol i ONLY have spray ins done, i have 3 trucks w/ them, one being a 02 PSD (work truck) my 2006 chevy 2500 (dd) and my older 1980 f-250 (old work vehicle) i do all kinds of consturtion and with the rhino, it never chips, and if it does take it back to where you got it spraied and have them do it again, (only the rhino war.) i think but either way i've hit mine w/ a shovel and had no breaks, sooo i'm sure you wont have a problem (spray in is a bit more though)
