P1151 code
Old Mar 21, 2006 | 05:55 PM
Dan O's Avatar
Dan O
new problem P1151 code
any idea where i should look to take care of this one?
thanks,
Dan
Old Mar 21, 2006 | 07:34 PM
BrianA's Avatar
BrianA
P1151 OBD Trouble Code
Technical Description
Lack of HO2S-21 Switch, Sensor Indicates Lean
What does that mean?
A Heated Exhaust Oxygen (HO2S) sensor indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time.
Symptoms
You will likely not notice any drivability problems.
Causes
A code P1151 may mean that one or more of the following has happened:
Electrical:
Short to VPWR in the harness or HO2S
Water in the harness connector
Open/shorted HO2S circuit
Corrosion or poor mating terminals and wiring
Damaged HO2S
Damaged PCM
Fuel System:
Excessive fuel pressure
Leaking/contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Induction System:
Air leaks after the MAF
Vacuum Leaks
PCV system:
Improperly seated engine oil dipstick
EGR System:
Leaking gasket
Stuck EGR valve
Leaking diaphragm or EVR
Base Engine:
Oil overfill
Cam Timing
Cylinder compression
Exhaust leaks before or near the HO2S(s)
Possible Solutions
See the above list of causes and go from there.
Hope that helps!
Old Mar 22, 2006 | 07:49 AM
projectSHO89's Avatar
projectSHO89
Condensed version - probably the O2 sensor (upstream - driver's side) is getting lazy.
Fuel economy will be affected if it's gettting bad.
Steve
Old Mar 22, 2006 | 10:13 AM
BrianA's Avatar
BrianA
Thanks Steve
Sorry for not being a little more direct.
But, I agree with his idea. I'd start with the O2 sensor.
I have never had one fail in my truck, but two have gone bad in my wife's Lexus. Similar code info.
Each time, a new sensor cured the problem.
Stv1968
Delaware Chapter
19
Mar 16, 2009 09:36 PM
SCRWDRVR
Delaware Chapter
Dec 31, 2008 06:44 PM
JeremyH
Offroad & 4x4
27
Feb 11, 2004 11:21 AM
Dan G
15
Jan 28, 2002 01:32 PM
Dan
Sep 14, 1999 07:53 PM
