Oil pressure problem?!
Old Mar 21, 2006 | 06:33 PM
WRA7488's Avatar
WRA7488
Well, i know this is a well discussed problem on here. I have a '94 f-250 w/ a 351. Engine starts with normal oil pressure, or with the needle below the "N" in "normal" but above the red line. If it says its low, it usually goes up to normal after a few minutes. Sometimes the gauge just swings down to low while cruising along. I dont think theres anything wrong with the truck given the amount of info on the gauges, but it just worries me. Any advice? could the sender be on a bad ground? thanks.
Old Mar 21, 2006 | 07:08 PM
quicklook2's Avatar
quicklook2
if you read the other 1000 post on this than you know it is an idiot light.
get a mech. gauge and find out what your true oil pressure is.
