Customer wiring harness
Old Mar 20, 2006 | 09:49 PM
sgrol's Avatar
sgrol
I found some unused wires up under the steering wheel labeled something like customer wiring harness, no plugs or anything just wires. Anybody know where the other end of these wires are? Tried searching for this but got no hits.
Old Mar 20, 2006 | 09:58 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
They're in the engine bay on the other side of the firewall. They are so you can run power to whatever equiptment you may want to add...i.e. customer access wiring.
Old Mar 20, 2006 | 10:07 PM
sgrol's Avatar
sgrol
Thanks Scott. I looked for them on the engine side but could not locate the other ends. Do you know more specifically where they terminate?
Old Mar 20, 2006 | 10:13 PM
cookie88's Avatar
cookie88
FTE Emeritus
They're probably buried in the main harness where it comes through. Not more than 8-10" from the firewall.
I had the opposite problem. They were sticking out on the firewall side, but I had to dig them out of the harness in the cab.
Old Oct 8, 2020 | 02:02 AM
marksman76's Avatar
marksman76
I am having trouble finding my pass thru wires in the cab of my 2001 F250.
Do I need to remove the kick plate down by my emergency brake?
I also found the light blue w pink tracer by OBD port that goes back to Fuse 27, 10a for customer use.
I believe thordehr was helpful on that.
I am going to hook up my lighted switch for my electric vacuum actuator for my Ranger AC mod to return to normal for heat in the winter.
Thank you!
Old Oct 8, 2020 | 06:12 AM
Dan V's Avatar
Dan V
They are above the throttle pedal.
Old Oct 8, 2020 | 11:37 AM
marksman76's Avatar
marksman76
I did see loose wires there along with the light blue with red stripe from fuse 27.
So I assumed the other loose wires also went back to my fuse block.
I will see if i can get continuity.
Thank you.
Old Oct 8, 2020 | 12:18 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
It helps to remove the knee bolster cover under the steering wheel. When looking underneath, look more toward the area above the center transmission hump, in line with the accelerator pedal, as was already mentioned. Don't waste any time looking over by the emergence brake pedal, even though in the engine compartment, the pass through wires emerge under the hood on the firewall right next to the driver's side fender, in line with the emergency brake.
The colors of the pass through wires under the hood match the colors of the pass through wires under the dash above the accelerator pedal towards the center stack. Unfortunately, some of the same solid colors are used for the trailer brake control circuit, so your continuity testing is a good idea.
rswhitmore
21
Dec 29, 2014 04:21 PM
dan187
May 18, 2013 11:38 AM
Narwhal
Nov 24, 2003 07:35 PM
JMR
Oct 2, 2001 11:49 PM
73Custom
Electrical Systems/Wiring
Jan 7, 2001 01:50 AM
