Modular V10 (6.8l)
Cruise control surge
Old Mar 22, 2006 | 09:14 AM
Fredvon4's Avatar
Fredvon4
Bronco2forever
Sounds to me like serious electrical gremlin and not mechanical. I would start making sure all grounds were clean and tight. I would remove each and every prodigy electrical connection to every Factory truck wire and make sure it is soundly and properly connected Preferably with soldered joints and NOT crimp on connectors. I would remove, clean and re install each and every electrical ground in the engine bay. I would disconnect every Factory connector under the dash and re connect them after inspecting for recessed pins (and fixing any found).
Good luck
Old Mar 22, 2006 | 01:14 PM
FastDEW's Avatar
FastDEW
Originally Posted by Fredvon4
Bronco2forever
Good luck
100% agree.
Old Mar 22, 2006 | 06:31 PM
bronco2forever's Avatar
bronco2forever
Thanks both and I have done some connector checks with a lot to go.
Gene Beaver RMC USN Ret W4PVI
Mikerage
1997 - 2003 F150
Jul 25, 2016 06:38 PM
mgraveman
Feb 26, 2013 08:53 AM
teerex
Nov 12, 2011 02:35 PM
jeffnick
Mar 28, 2010 03:30 PM
redone1
27
Sep 10, 2009 07:42 AM
