Left Turn Signal Problem
Old Mar 20, 2006 | 06:54 PM
Dmpglide's Avatar
Dmpglide
Hi ALL! I'm new to the forum
I have a 1986 F350 with a 6.9D I just purchased and have found some problems and one of them is the left turn signal. The socket has 3 wires out the back of it. It uses a 1157 bulb. I have power to the socket the parking light works. With the turn signal on and a test light touching the socket terminals I have power and the test light does flash. When I put the bulb in I have no signal, but do have a park light. I cut the wires and added a new socket and still the same problem. I have used 4 new bulbs. Any ideas??
Thanks, Dave
Old Mar 21, 2006 | 10:10 AM
1975Ford's Avatar
1975Ford
When you put the bulb in, does the front signal light blink?
Have you checked the ground wire on this left turn signal?
--Buck--
Old Mar 21, 2006 | 02:40 PM
Dmpglide's Avatar
Dmpglide
No, No blinking. I haven't taken the time to check the ground, but that was my next step once the weather warms up.
