blackston report
Old Mar 20, 2006 | 06:22 PM
busdriver47's Avatar
busdriver47
blackston report
got my report today understand most of it. but where do you see what your oil has sheared down to.
Old Mar 20, 2006 | 06:27 PM
velnof's Avatar
velnof
How do you go about doing this? Where do I get the information about where to send my oil, in what container. and any other info I may need to know.
thanks glen
Old Mar 20, 2006 | 06:34 PM
busdriver47
If you go to there web site you can get the info you need
Old Mar 20, 2006 | 06:41 PM
utahtom's Avatar
utahtom
At the bottom, there is a column for viscosity
Old Mar 20, 2006 | 06:47 PM
busdriver47
I read that it says tested values were 64.9 % at 210 f so what does that mean. one good thing was fuel was 1.5% 7800 miles on motor.
Old Mar 20, 2006 | 08:37 PM
RJB1's Avatar
RJB1
thanks glen
Google blackstone labs. You can request the kit to send in, they will explain the rest in the instructions. I think it cost ~$18.00 for the analysis.
Old Mar 20, 2006 | 08:42 PM
dieself250's Avatar
dieself250
read the column that says values should be. viscosity @210 should be between 69-80
yours is 64.9 witch is not good, fuel at 1.5% is not good. fuel should be less then 0.5%. you might have a bad injector. what is your flash point, it should be higher than 410, my 2nd to last oil report for my 7.3 idi that has over 180,000 miles is better than what you are saying your 6.0 is viscosity 80.6, flash point 409, fuel 0.8% i had a bad injector, after replacing the bad injector viscosity 75, flashpoint 440, fuel less than 0.05% I would suggest getting your truck looked at.
the address for blackstone is http://www.blackstone-labs.com/ , they will send you free containers for samples
Old Mar 21, 2006 | 09:16 AM
M. Kelly's Avatar
M. Kelly
engine oil viscosity
What viscosity was the new engine oil? 10w40,15w40, etc...
I did not see it listed. Thanks Mike
Old Mar 21, 2006 | 04:01 PM
busdriver47
It was my second oil change the dealer changed it at 2900 .The dealer used 15W40 motercraft. I changed it at 7894 i used delo 400 15W40.
Bkl251988
Oct 14, 2022 10:59 AM
Deborahglider
Car/truck Buying Advice
May 13, 2015 04:47 PM
ligito
Apr 29, 2015 10:18 PM
superhooperduty
Mar 3, 2014 10:05 PM
jniolon
37
Jun 13, 2013 10:20 PM
