oil pressure
Old Mar 20, 2006 | 01:57 PM
RWALTONKY's Avatar
RWALTONKY
oil pressure
I have a 85 ford 6.9 turbo diesel. When the motor is warm the oil pressure is about 15 p.s.i. at an idle. Is that good or bad? I recently had another truck with the 6.9 diesel but it wasn't turbo. It had a higher oil pressure at an idle.
Old Mar 20, 2006 | 03:53 PM
bilder12's Avatar
bilder12
put a mechanical guage on it and be sure what the pressure is. The factory guages are worth about 1.50. The sending units are not worth much more. The 6.9 are a low pressure engine but high volume. To be sure, get mechanical guages.
Old Mar 20, 2006 | 04:40 PM
RWALTONKY's Avatar
RWALTONKY
I do have a mechanical gauge installed on the truck. Thats how I determined the 15 p.s.i. The original truck gauge at an idle bottoms out.I just wanted to make sure thats a good pressure for my motor.
Old Mar 20, 2006 | 05:45 PM
dieself250's Avatar
dieself250
15@ idle is ok at 2000rpms it shuld be 40 to 70 psi at operating temp
Old Mar 21, 2006 | 01:11 PM
RWALTONKY's Avatar
RWALTONKY
oil pressure
When you are at a higher rpm when its cold it will not do more than 60 p.s.i. When its warm between 40 and 50 p.s.i. at the most.
