wiper motor issue
Old Mar 20, 2006 | 07:23 AM
ksvtwin's Avatar
ksvtwin
wiper motor issue
Hello, i have a '92 ford full size and the wipers won't work. They are delay wipers. when i turn the switch, i can hear the relay working under the dash on the passenger side. i checked the fuse/breaker and it is good. I put on a new motor thinking that was the problem and it still doesn't do anything. is it the relay even though it clicks?? Thanks, Kent
Old Mar 20, 2006 | 07:32 AM
SR_Crewchief's Avatar
SR_Crewchief
Pull the switch. Check that your getting good current to it and then check that your getting good output. Next check that your getting good current to the motor with the switch on. This should hopefully isolate where a wiring problem exists, if there is one. Double check that the motor is grounded proberly as well.
Old Mar 20, 2006 | 07:21 PM
water 5's Avatar
water 5
mine was clicking too and would work half of the time change the clock spring comes with a new turn signal lever and works fine now.
