i am currently looking into buying a set of rust free doors. will 68
window regulators work in a 67 door? how do i tell if the door is a 67
or a 68-72.the doors i am looking into do not have regulators so i would have to reuse mine. can you tell from a picture if a truck is a 67 or a 68 or older truck? thankks
kevin
The physical door will be the same from 67-72. The inner door panel will be different(might have vinyl cover or just plain steel). By my catalog, the 67 door handle and window regulator will be different from 68-up. Look at the inside door panel and if the door handle to open door is a lever you pull up, then it is 67. If the inside door handle is inside the arm rest then it would be 68-up.
Larry
1967 F100 352/c6
1969 F100 428CJ/4 spd
1959 B model Mack
and a few hot rod FORD cars too
