tires
Old Mar 19, 2006 | 08:14 PM
southerntoy's Avatar
southerntoy
tires
Hey i have a 91 f-150 with a ford 8.8. I already have a 3" body lift and i am thinking about putting a 6" suspension lift. What is the largest size tire i could put on my truck with the stock axles and still be alright.
Old Mar 19, 2006 | 08:19 PM
Kerrythis's Avatar
Kerrythis
Try
http://www.discounttiredirect.com/direct/home.do
They have helped me with custom wheels / nitto tires.
Old Mar 20, 2006 | 08:17 AM
TexasGuy001's Avatar
TexasGuy001
From what I have seen people say, anything over 35s is pushing the limits for the 8.8 axle etc. You might be able to go slightly larger. I would think that 38s would definitley be pushing it though. Don't quote me on this.
Old Mar 20, 2006 | 08:23 AM
Socrates's Avatar
Socrates
35"s are gonna be pushing it with the TTB. If it is 2wd then it might be ok, but I would steer clear of big tires on the TTB. Spend your money on a solid axle swap and then lift it for bigger tires. My last truck (90 F150 4x4) has nasty steering issues with a 6" lift when going fast offroad. The 8.8 seemed to hold up good with the 36"x15.5 tires, but the front end was crappy. Also, anything over 33"s and your brakes are gonna suck.
Old Mar 20, 2006 | 11:33 AM
Dr.Reese's Avatar
Dr.Reese
I had 35 12.5 on my 88 with only 4 in the front and 2 in the rear suspention lift i think with 9 in total you should be able to get at least 38's and 44's would proble rub unless you cut the fender wells
Old Mar 20, 2006 | 11:38 AM
s8whiskey's Avatar
s8whiskey
Take pictures if you put 44 on a 8.8 and TTB I wanna see the distruction haha but No larger then 38's and thats on the road and LIGHT off road. You can do 35 comfortably on and off but you are going to have problems with the TTB
Old Mar 20, 2006 | 02:14 PM
southerntoy
would 37X13 be too much tire? It's not a daily driver anymore just off-road in it occasionally. Also what gears would you recommend and where can you get a decently priced set at?
Old Mar 20, 2006 | 05:22 PM
Thomasm67's Avatar
Thomasm67
37's you can probly get away with but as everyone has pointed out you will have problems with the ttb you'll be wearing out bearing's your tires won't stay aligned. As for gears 4.10's would work or you might have to go with 4.56's.JMO go with 4.10's and 33's with just a what you have already on your truck. or just go with a 4 inch lift.
