FT Engine info
Old Mar 19, 2006 | 04:58 PM
Kerrythis's Avatar
Kerrythis
Question FT Engine info
The VIN on my newly aquired 65 is F25JR652078, the way I understand this truck was born with a 6cyl,
but ... it has a V8. According to "How to Rebuild BB Ford" this engine is a FT 330HD/3.875 or 359,363/4.05 or 389,391/4.05. Markings on the block include the mirror image 105 (left front) and the DT3E on the right side which includes a pluged oil return line in the side of the block, this indicates the FT block ...
OK are you still with me?
My question is how do I determine which CI I have, the 330, 331 359, 361, 391? And the Year? BTW it has a 2 barrel. Kerry
Old Mar 19, 2006 | 09:13 PM
rusty70f100's Avatar
rusty70f100
You may not necessarily have an FT. I have two regular FE 360 blocks out in the garage with the mirror 105 and the D3TE casting number. Go look at the head casting number. It is between the center two spark plugs. That should determine it's FT-ness.
To see what displacement it is, you need to either:
1. Measure the bore and look at the crankshaft casting number, or
2. Measure the bore and measure the stroke.
Old Mar 19, 2006 | 10:49 PM
Kerrythis's Avatar
Kerrythis
Hello and thank you,
I'll get back to when I figure it all out ... what year could I expect this engine to be?
Kerry
Old Mar 20, 2006 | 12:44 PM
rusty70f100
Well the block is a D3TE, so the block is at least 1973.
giantfr0g
Feb 28, 2009 12:47 AM
mikem55
Jan 11, 2008 07:02 PM
krewat
Nov 28, 2007 04:21 PM
hoxiii
Oct 2, 2007 05:20 AM
Abuildr4u
May 16, 2006 10:58 PM
