Trans upgrade
Old Mar 18, 2006 | 10:58 PM
Dually02's Avatar
Dually02
Question Trans upgrade
I am putting the Dieselsite trans filter kit on. And changing to Amsoil Series 3000 Synthetic 5W-30 oil with Lucas Synthetic oil stablizer. I would like to upgrade the trans so it with shift better. I thinking the Factory tech valve body by the Dieselsite, or the Sonnax. What do you guys or girls think. Thanks
Old Mar 19, 2006 | 08:08 AM
cangim's Avatar
cangim
That really depends on what you are looking for. I have had the sonnax kit, and it works really well, it is in no way comparison to the Transgo Repro kit I installed. BTS Valve bodies are very popular as well, especially if you are going to get a DP tuner chip down the road, as Jody has a really good program to work with that specific Valve body. The Cost vary as well, 50 for a sonnax, very well results. I know the others are closer to 200. The transgo Repro kit requires alot more to install than the sonnax or the BTS VB. Do some searching, decide what will work best for your wants/needs.
Old Mar 19, 2006 | 08:25 AM
Dually02's Avatar
Dually02
I will be getting the DPtuner chip soon. Also MBRP dual exhuast. I do like the BTS valve body kit. After that I'm hoping to do a turbo & intercooler.
Old Mar 19, 2006 | 08:36 AM
cangim's Avatar
cangim
Well if you are definately going to get the DP tuner chip then I would strongly encourage the BTS VB.
Old Mar 19, 2006 | 08:50 AM
Dually02's Avatar
Dually02
Then that is the way I'm going. Thank you so much for your help. I hope to do the same for you.
Raymond
