I have a new 06 EB Expedition 4x2. We love it so far! We have only had it a couple of weeks. When we first got it the reverse sensing system worked fine but I have noticed it does not sound anymore. When you put it in reverse, the display on the dash says it is on but you do not hear any noise.
Any thoughts on this? If it says it is on when you put it in reverse, but there is no noise, I guess it must have broken already? I can't imagine it would stop so soon. I hope it is operator error and it's something simple. Anyone have similar problems?
Do they put 4 sensors on the new ones? I've got an 03/EB with 2 sensors that is supposed to be a better system but has gone out. Just says "check backup aid".
Just wondering.
Mine stopped working after we had a lot of rain. Was out for a couple of weeks, then it started working again. I think moisture gets in a sensor and disables the system. After it dries out it works again. JMO
I know if dirt gets on the sensors, they wont work.
mine just plain dont work any more... alot of thing quit working...
driver's seat, back up sensors, and overhead trip computer...
and hubby says fuses are fine. This is quite irritating!
For all of those things to go out at the same time I would suspect a fuse, or a connector. There are fuses inside and there should also be some under the hood.
